Okay, so Festiva brake discs are skinny little things and the bearings require a specialist to replace properly, big problem. We can use Aspire, Kia Rio and Capri hubs and brakes as a high performance replacement. All change the bolt pattern and have different bearings. Which is the easiest conversion, which has the best, easiest to replace bearings. I'm guessing since the Kia is the newest, they would probably be readily available the longest. What about drilling the conversion with the Festiva bolt pattern?
Inquiring minds want to know,
