so I have the rio front swap with 1.5coils cut off and like it .
I have an aspire rear beam and struts that im swapping in.
I am going to put a hitch on this car to pull small trlr and light weight things so with the extra load on the suspension what springs do I need to run?
im not buying anything expensive either.
ive read to use rear aspire springs cut but how much do I cut?
ive read to use the front festy springs the way they are will it work?
ive read some people switching to Honda springs this may beit bc they are progressive springs.
I don't want my car lowered or raised I just want stock height with the ability to support some weight in the rear or be able to pull a trlr without sagging severly or rubbing?
thanks a lot for the info
