PICS NOAW.
air shocks on rear
don't cut the beam open, just cut away the strut mount untill there's just the bolt left then cut that in half and pumch the pieces out. a small open ended wrench can easily hold a new nut for re-assembly.Trees aren't kind to me...
air shocks on rear
Sounds sweet.Last edited by Flyin4stroke; 08-28-2013, 06:52 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
If the MA-822 can be made to fit, we might also have the ability to use these for an aero mod for increased MPG via lowering the vehicle.Last edited by Pu241; 08-28-2013, 08:14 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yeah. Alot of upgrades and benefits out of a simple swap. Can't believe I never thought of this before. They are on eBay right now less than 80 shipped. Plus they would be bad with a remote valve hidden away
Sent from Kingston Ga from my hillbilly handheldLast edited by kingstonpygmies; 08-28-2013, 07:38 PM.90 festy with 92 FI motor. Digital camo paint. BHAF. short throw. currently 47 MPGs
Need something on the front to be able to raise and lower the vehicle and keep it level.Last edited by Pu241; 08-28-2013, 08:15 PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
turns out I also need air lines as these 822's didn't come with them like the others did. so will get the line kit tomorrow part# http://www.oreillyauto.com/site/c/se...p?keyword=ak29
by the way the shocks are just as cheap through your local oriellys.by the time u pay shipping
also has a different lower bracket hopefully figure that out as well.Last edited by 1chrisapple; 08-28-2013, 08:26 PM.
yea I hope someone matches up some fronts as well.Originally posted by Pu241 View PostNeed something on the front to be able to raise and lower the vehicle and keep it level.Last edited by bobbyspider; 08-28-2013, 09:12 PM.
Might have to do the make your own koni yellows trick we have to do on srt4. You take a stock strut cut it apart and use the housing to hold the koni. Would that work, turning a shock into a strut being so small?1993 GL 5 speed
