i dont know much about offset. will these fit without any issues on the suspension side of the wheel/tires i know about how they will stick out of the fenders but thats what im looking for i just cant have them hitting my suspension and stuff
13x7 wheels with 0 offset
I wouldn't attempt it, crazy offset like that has to ne rough on bearings. I like the wheels tho. We used to run similar wheels when I raced oval track-Greg
Redneck Engineer
FOTY - '09
Be an innovator...see of you can get them cheap enough?-Greg
Redneck Engineer
FOTY - '09
1993 GL 5 speed
they will fit, they will be a bit harder on the bearings (outer rear especially). the car will handle very differently.
closer to +15 methinks, but that would give you an idea on how the car will respond. and remember that your green wheels are only 6" wide.Originally posted by bobbyspider View Post^ are my green wheels 0 offset?
the extra 1" makes a differance (that's what she said).Trees aren't kind to me...
BUSTIVAS signature pic
And if you get nosy in his other pictures that are hosted you definitely have to gnaw gnaw gnaw at your metal to rock them. which i would do as well. get some flares or go rough, does not matter.Last edited by getnpsi; 10-19-2013, 01:46 AM.1993 GL 5 speed
well ill be picking these up soon
im trading the guy a set of 16" wheels that i had laying around and would most likely never use.
they will be going on the surf blue car. im either going to do a surf/yellow or a surf/pink theme with the car. my wife hates the idea of tealis and pink so she is leaning toward yellow but i think rocking pink wheels and graphics would be pretty tight
Mine are +\- 36 or something like that, whatever stock is, go to 0 then go past that 36mm!
Do it! 175/50's are the tires that came on my rims with a real nice stretched look. They're on ebay occasionally, probably never find them locally.
The problem with mine isn't clearing suspension parts, with normal tires there isn't a problem at all, but with 185/70's they like to hit the bumper or fender when I turn too hard. Making a turn at at intersection isn't a problem at all but you gotta swing wide to get in certain parking spots, like your driving an 86 f150 with a 3" lift and 35's... So I'm kind used to it anyway and the look is worth it.Last edited by zoom zoom; 10-22-2013, 10:36 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
