Is this an easy solution to handling trailer tongue weight on a stock Festiva?
  • AlaskaFestivaGuy
    replied
    Did you use the "5 door" Aspire rear springs, or "3 door." I don't know anything about Aspires -- do we even have 5 door versions in North America?
  • 1chrisapple
    replied
    Alakan man hey i ended up using stock rear aspire springs uncut on mine and it handles just as much as the air shocks did plus no worries on one blowing out.
  • AlaskaFestivaGuy
    replied
    gergorian,
    I'd really rather not mess with having to carry two different spare tires (plus one for the trailer, of course), making three.
    bhazard,
    I've never had any problem with stock brakes or 12" tires that are readily available in Seattle. Since cars don't rust in the NW, we still have quite a few Festies running around here, so little tires are readily available. On the particular car I'd be doing this to, I've run it across places like North Dakota indicating 85mph without the slightest bit of shaking.
    gestiva,
    I was thinking air shocks until I saw how this turned out (poorly):
    Discuss improvements to your Festiva or Aspire in the handling, braking, wheels and tires areas.
    scitzz,
    I'll wander through the weeds tomorrow to see if I've got some front springs here. I know I have some up in Los Anchorage.
    Anybody,
    Does anybody know what's different between Festy front springs and Aspire 5-door rear springs?
  • gestiva
    replied
    Why not install adjustable air shocks? With air shocks you can adjust the stiffness for normal driving, and easily add air to make the rear stiffer for hauling a trailer. In my build thread for my white BP festy, there is info and pics of the air shocks I used and when I hauled my trailer with a 450lb bike it handled like I wasnt towing anything... just a thought....
    Sent from my SPH-L900 using Tapatalk
  • Aaronbrook37
    replied
    Originally posted by bhazard View Post
    Well think of this...wouldn't you want real brakes on the car if you were using it to tow? Not to mention...real tires.
    Brad's got it right here. I'm willing to bet that a decent-sized trailer has better tires on it than my grey car's 145/80/12's.
  • scitzz
    replied
    Even before I did the Aspire swap, I grabbed a set of Festiva Front springs, and put them on the rear. No more problems with tongue weight, Class1 stuff at least. Ride is a little stiff, but the handling, oh my!
  • bhazard
    replied
  • gergorian
    replied
    The only real difference between the Festiva beam and the Aspire beam as far as I know is that the Aspire has an integral "swaybar" if you will, to help reduce body roll. Other than that and the fact that the Aspire beams bolt pattern is 4x100 to the Festivas 4x114.3, I dont think one is stronger than the other but I could be wrong. As to your question on the springs, I would guess that the 5 door Pride spring would handle more load but you would get a stiffer ride when not towing anything.
  • Is this an easy solution to handling trailer tongue weight on a stock Festiva?
    In this thread:
    I found that attached photo along with this description in a post from F3BZ:
    "the spring on the right is the rear spring for the 94 5 door pride. the one on the left is a stock 3 door festiva spring. all dimensions are the same except that the wire diameter for the 5 door spring is 1/2 mm larger in diameter (10mm). when plugged into a simple online spring rate calculator the 5 door spring is almost 25% higher force for each inch of compression. (97 lbs./in. vs 121 lbs./in.). part# KK153 28 011. $25.45 [from FourGreen]"
    Would this be an alternative to an Aspire rear beam (for which I've never been able to determine if it can handle more weight than the stock Festy beam) and its different wheel bolt pattern?
