Festy springs w/Kia struts?
  • Festy springs w/Kia struts?
    Can we use Festy front springs with Rio struts, i.e. do they fit? Are the Rio springs longer? Stiffer, and if so what is the rate?
    They fit but the rio strut is taller since they don't have the offset top hat. Will work fine, dampening is different too, can't explain how but it's better.
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      i know its an old thread, but instead of buying festiva struts to replace the oem ones, i can buy rio struts and they will fit and require no customization to work?
        Rio struts have a larger rod diameter. Change the mount and they will work correctly. Mounts are available from Rockauto.com at a good price. Use the ones for a 2001 Rio. That's what I used for mine. They have the bearing and the 2 hole mount pattern you need for the Festiva.
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
