I am in process of making some DIY coilovers and and curious if the Kia Rio strut mounts (front) fit on the Festiva strut? I have searched just little confused.
rio strut mounts
rio strut mounts
1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
ok may be stupid question but what is that and where can I get them at?Originally posted by shadetree View PostNo they don't . You will need a bushing adapter .1990 Red Festiva STOCK "pregnant roller skate"
You used stock struts as well?Originally posted by Team Lightning View PostI used the Rio struts on mine when I built them.1990 Red Festiva STOCK "pregnant roller skate"
Sorry read that wrong1990 Red Festiva STOCK "pregnant roller skate"
I used KYB struts for a 2001 Rio.Last edited by Team Lightning; 02-03-2014, 09:24 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I already got 4 brand new festiva struts so i curious to know if the mounts work. No big deal really. I probally go with different setup on the 2nd festiva that I not even started on yet.1990 Red Festiva STOCK "pregnant roller skate"
OK think I will pass on this one then I still got another festy to work on so all good thanks all for the help1990 Red Festiva STOCK "pregnant roller skate"
I'm in the middle of my re-install. I cut 1.5 coils off the rio springs and think the car still sat higher than original. Now I barely have preload assembled off car (sketchy?) You should use complete rio struts; if you can exchange the 2 front ones i suggest doing so!1993 GL 5 speed
This was just experimental more than anything. Believe it or not I put all 4 struts on about 2 months ago new. But I came into 4 more brand new festiva struts so decided to try some coilovers. If I decide to go that way on my other one I will use rio struts.1990 Red Festiva STOCK "pregnant roller skate"
The 2.5 spring setup with the specific honda civic sleeves is a solid choice from the other thread by pheonix. I'm simply doing the cut stronger rio spring just to see how it goes for now. I have extra festiva and aspire springs to make up for error or overzealous lowering choices in the meantime
But your question is about the strut. If you can fabricate, make what you have work. if you can get the rios, go as much rio components as you can.Last edited by getnpsi; 02-03-2014, 11:55 PM.1993 GL 5 speed
