Is it possible to fir 14 or 15 inch rims with the 4x114.3 bolt pattern onto a 91-93 festiva?
Rims and tires?
Yes it's quite possible, I have 14'' wheels on my car with 185/65/14's Cooper CS3 I also have a set of OZ 15's with 185/55/15 tires, you do need to make some changes for these wheel combos to work, on the front I chose to use 2000-02 Kia Rio front struts W/uncut springs, on the back I used Aspire struts made by Monroe with Festiva front springs also uncut, in addition I used a half inch spacer dowel pinned to the brake drum, I also re drilled the brake drum to accept studs, no big deal just takes a little time. Good Luck and let us know what combo of wheels and tires you plan to use.An idea can turn to dust or magic, depending on the talent that rubs against it.
Remember that to use the Miata wheels, you need the 4x100 bolt pattern.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
