My passenger side rear spindle was cross-threaded, and now my drivers side got cross threaded as well.I have an aspire rear beam (unusable) and have taken the cotter pins from it. I have some brass bushings that have the perfect inner diameter to fit over the spindle threads. I was wondering if it would be safe to drill through these bushings and the spindle, then place the cotter pin through the whole assembly to hold the washer/ wheel bearing/ drum on? It seems like it should work at least for a while, and then I can pull the spindles off the aspire rear beam when I have time and swap them over.
Sent from my SCH-I605 using Tapatalk
