I searched before I posted this, all apologies if this is in 2999 other posts that I just happened to miss.
So, the "Aspire Brake EZ how to" suggests that you remove the Aspire rubber portion of the fluid brake lines - why can the festiva's not be used? I understand the brake CABLE exchange and everything, but I do not understand why you would NEED the aspire brake lines when removing it from the aspire...?
Thank you.
Thank you.
