I have a stock 1988 Ford festiva, will these wheels fit and what size tire to use if they will fit. http://www.summitracing.com/parts/rl...584s/overview/
Will these wheels fit?
That says 4x100 for the bolt pattern. Stock Festiva is 4x114.3. They will only fit if you have the Aspire swap.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
92 GL was red automatic Ms Va., now Zinc Yellow
Originally posted by Team Lightning View PostThat says 4x100 for the bolt pattern. Stock Festiva is 4x114.3. They will only fit if you have the Aspire swap.Last edited by TominMO; 08-21-2014, 05:22 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by 454vortec View PostI have a stock 1988 Ford festiva, will these wheels fit and what size tire to use if they will fit. http://www.summitracing.com/parts/rl...584s/overview/
BTW, nice rims! I'd rock them.Last edited by drddan; 08-21-2014, 11:43 PM.Dan
If you will go to roadkillcustoms.net they have a wheel bolt pattern tool that will tell you the bolt pattern on most vehicles. It will also tell you what other vehicles have the same pattern. I put a set of 14" 5 spokes from a late 90s Elantra on my first Festiva back in 2011. But even the narrowest 14" tire I could find scrubbed the spring plate on the strut. I had better luck with 13" steel Metro wheels. I just had to use spacers in the rear.
Someone mentioned Miata wheels. They are 4x100 MM and won't fit Festivas. I wish they would! Those were the first ones I tried when I had my first Festiva and worked at a salvage yard. I was looking at Panasport wheels on line last night. I LOVE them but they don't come in anything smaller than 15". I really want to stick with 13"s but it's hard to find anything cool in a 13' wheel.
Jason, If you do the Aspire swap, you can run those Miata wheels. I have the solid spoke Miata wheels on my 90L.
Oh, and Welcome!!Jerry
Team Lightning
93 L Lightning. BP
Originally posted by Team Lightning View PostJason, If you do the Aspire swap, you can run those Miata wheels. I have the solid spoke Miata wheels on my 90L.
Oh, and Welcome!!
