Originally posted by ajb999
Aspire swap done, having some issues
ask for a front brake hardware kit at your local parts house. that should have that and other stuff also that may have been damaged or just plain left off over time before you got the car. in the meantime use some cotter pins or wire to hold those pins in so they can't work out=no brake!91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
yes all my little wires/springs are rusted/broken. i used paperclips on the pins so they don't slide out and yeaseterday i bought a pair of the anti-rattle springs. i knew my pads were rattling around a lil but i didn't care much; i knew that wasn't causing my problems.
Karl is sending me some new rotors, because i was at a loss as to what else might be to problem. (thnx!)... but then when i was putting the anti-rattle springs on i noticed something i had not previously noticed...
on my pass side caliper (brand new from AZ) the lower mouting bolt was loose! well, the bolt itself wasn't loose. the sleave that the caliper is supposed to slide on is loose! it could fit one that is about twice as thick. the sleave in there is the same size as the old sleave from the old caliper, but the whole in the caliper is much larger. this allows the caliper to "cock" a little, and since that rotor is a little warped and the pads were stopping on the corner it was causing that clunking noise. Now i don't know what to do! Has anyone seen this before? my drivers side was fine the caliper just seems to have the wrong size bore on the pass side... any way i can find a larger bushing? any ideas anyone?
thanks,
-a rather frustrated nate who doesn't want to buy a new caliper...~Nate
Current cars:
FOTY 2008 winner!
If that caliper was "brand new from AZ," then take it back and show them. You should be able to get a replacement at no charge if it came with a wrong-sized slider.
You should be out just the time and bother.
AZ= autozone.... :lol:
i figured i could do taht if i have to, but i've already painted them and all and i returned the old ones for the core charge so i don't ahve the box. i do have the reciept still so if i dont' find anything else thats what i will do... as for now i should say the car dos at least stop better b/c i almost hit a deer last night but stopped in time
thanks guys!!~Nate
Current cars:
FOTY 2008 winner!
just clean off the paint before you return it so they can't try to claim it isn't theirs.91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
If they are defective then return them even if they are painted, it shouldn't matter. I'd even ask them to give you a new can of paint for the replacement.
^^ Thats right ,it should not matter paint or not , even if they went bad in a month they will still replace them ,even if painted, they are under warranty, you have a receipt yes ,
Autozone will replace or refund anything with a receipt .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
