After having a conversation with Gomez, and reading this nice pdf about traction, I was wondering what the largest size tire someone has made fit on their festiva?
(My 10 minute knowledge after reading the page):
Basically "tall" tires (higher circumference) have a longer point of contact with the road in the direction that one is traveling. i.e. more traction. That is compared to a wider tire with the same surface area of contact. Wider tires are going to cause more stress on most of your suspension components, as well as not having as much directional grip as the taller tires. But that doesn't mean having additional width to you tires is "bad". If you have X amount of surface area, you want it oriented in which the aspect would be more a 9:16(tall) vs a 16:9(wide). (bad metaphor, I'm tired.aspect ratios i mentioned are arbitrary.)
So, what is the Largest tire someone has put on their festiva? preferably in actual size AND circumference.
(http://tire-size-conversion.com/tire-size-calculator/) <-- for circumference
If you're interested in the article, link is below:
all input is nice.
all input is nice.
