So I got the aspire swap with new bearings, shocks,daisy miata wheels with fresh rubber. New rotors and the cheap set of pads and new master cylinder, new control arms, new tie rod ends, new ball joints, new axles. Theres more new parts on the car then old.
I just got the new set of daisy wheels and new tires hoping it would help solve the vibration. it did help but now i'm vibrating when braking. pretty bad to.. I have had to spike the brakes a couple times in traffic but its only been a little less then a year since the brake job. i'm thinking I warped the rotors. So do I machine them or get new ones is my question.
Problem 2 is in the drivers side front suspension. When I turn right up a slight incline say into a parking lot I get a snap/pop noise. I can almost feel it near my feet. remember all the parts down there are new accept the inner tire rod end (planned to replace the whole steering rack assembly and then get it aligned again. I just had it aligned like less then a year ago. I have checked a couple curbs with the front end delivering pizza so is this enough to mess up the alignment? its pulling a bit to the right. And what's snapping in the front end??
One more thing. I replaced the rear struts and if i'm on an uneven surface while driving I get a jiggling shaking noise from the right rear. on an even road surface there's almost no sound but its very noticeable on gravel. I haven't taken the time to take it apart cuz I need my car. Its functioning fine but the jiggling is super annoying. Other then these problems this is the best car dollar for dollar I've ever had. Thanks in advanced to anyone who replys!!
