aspire suspension swap questions
  • #16
    Use the mc and booster too. Much better braking when you use the Aspire mc and booster.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
    • #17
      ok cool and thanks every body now i can start assembling a good parts list to take to jy oh and one last thing what year rio's or does it matter
      88 L carb'ed (when up in flames of glory)(deceased) 4spd
      89 L carb'ed (died on the operating table (rust))(deceased) 5spd
      93 gl FI (sold) automagical
      89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
      88 L carbFI megasquirted zombie car
      • #18
        Lots of 'Ho hum' being forwarded here.
        Aspire swap is primarily advantageous because 1) it uses 4 x 100 bolt pattern wheels (so you can escape from trailer tire sizes), and 2) the front disc brakes are readily serviceable quite unlike the primitive Festy 'garbage' set up. And overall the brakes (front and back) have considerably more surface area and therefore more purchase and longevity when bolted into a Festy.
        Far and away the best thing you can ever do to a Festy.
        • #19
          ^^^ What Bert said sums it up very well.
          Ian
          • #20
            Haha the forum has come along way. I remember when only a few people had aspire swaps and capri brakes where a huge deal. Now it's totally different. People now have had aspire swaps on festivas for yrs. loving it.
            1989 Ford Mustang GT 5.slow
            1996 Ford F-150
            • #21
              Aspire swaps are old news. Now it's Rio swaps.
              91GL BP/F3A with boost
              • #22
                You can use the festiva MC and brake booster. But get the aspire ones and switch when the festiva ones go bad.
                Use Festiva lca arms.
                David
                • #23
                  01 02 rio struts and top hats(2 bolt).
                  I also try to get the aspire wheels and wheel covers. Don't forget the spare! I like to use Protégé spares there a little bigger and easier to find.
                  David
                  • #24
                    Well sort of. Early Rios are good for front end stuff but doesn't get you an improved rear beam with bigger brakes and 4 x 100 bolt pattern. Nor stiffer rear springs and higher spring perch shocks. Still the easiest, if you're looking to do a thorough upgrade, is to scout out a complete Aspire to scavenge from.
                    • #25
                      can you combine Aspire front struts with the Rio 2 bolt bearing style hats?
                      • #26
                        bumpup
                        • #27
                          I might be wrong and if I am someone will surely correct me. If I remember correctly what I read the Rio hat has a larger diameter center hole than the Aspire strut shaft.So some type of bushing will be necessary to combine the two.
                          • #28
                            HI there could you tell me what year was the the Kia Rio you did the swap with.please. I would like to do upgrade mine too. please reply me when u can
                            89 Festiva L Automatic, black ,Bought 6/29/15 ,Not Running!!
                            90 Festiva L Stick , Aqua ,Bought , DD
                            03 Chevrolet Silverado 2500HD Crew cab , White,
                            • #29
                              My left one came from an 01 and my right one came from an 02.
                              • #30
                                thanks now i know
