Sorry to hear that Tom. How tight were your top nuts? The bushings should only have a little squish on them. If the nuts are tightened too much, the bushings can't move as the. The top of the shock needs to articulate fairly freely or the shaft will flex as the beam moves through it's stroke and articulates. There is a lot of movement at this pivot point.
If the shock shaft is flexing, it will prematurely wear the bushings and seals inside the shock.
