Here's why: first off, its not practical to have two different bolt patterns, even if you have dual-drilled wheels like I do. You would still need to keep two spare tires (or a dual-drilled spare). There is also an extra stabilizer bar on the aspire rear beam that really stiffens things up. But here is the real reason... I keep reading "I just want to swap the front because there isn't really that much difference between the festiva rears and the aspire rears"... here's the difference...
Aspire rears are much much bigger. The increase of size in the rear is actually greater than the increase in size in th front.
Poverty produces creativity
