Originally posted by Advancedynamix
new/better/more piston brakes
There you have it. The car weight, transmission type, tire diameter and potential use are factored into the design and engineering of the brake system. If you make changes to any of these without changing the brakes to match brake performance will suffer. Likewise if you do nothing to the car but mod the brakes the results may be less than desireable.Originally posted by azgtx View PostThen get a 1" master cylinder from a 91 929 and a booster from a 96 626...then proceed to throw yourself thru the windshield.
Do not get caught up in bigger or stronger is better. Just right is best. Do not forfeit your safety.Reflex paint by Langeman...Lifted...Tow Rig
uploadfromtaptalk1443290223570.jpgOriginally posted by Dragonhealer View PostThe stock brakes in a Festiva, in proper working order are great for all types of driving.
It's that towing that will bite you in the a$$ !
Sent from somewhere outside the asylum via tapatalkContact me for information about Festiva Madness!
'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
I run aspire brakes so I can still fit a 13 inch wheel with my slicks.
lots of stop and lots of go!
Last edited by Flyin4stroke; 10-06-2015, 11:41 AM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
