Originally posted by fasteva
Building the ultimate Festiva street suspension...
Originally posted by gergorian View PostHere is exactly what I bought and I have about 1000 miles so far on mine with no issues and a firm but not too harsh ride quality.
MK3 VW coilovers- http://www.ebay.com/itm/151380830285...%3AMEBIDX%3AIT 1x needed
MK2 VW rear struts- http://www.ebay.com/itm/271597130505...%3AMEBIDX%3AIT 2x needed
2-1/2" ID 10" tall spring- http://www.ebay.com/itm/NEW-RACING-C...item4386304e4d 2x needed
1-7/8" ID 10" tall spring- http://www.ebay.com/itm/NEW-MIDGET-R...item43a0bbb547 2x needed
small body coilover sleeve for 1-7/8 springs- http://www.ebay.com/itm/Bilstein-193...-/131499818068 2x needed.
You will also need a top coil perch for the rears. You could have one made or use washers form what I heard. The only modification you will need to do is to slot the upper mounting hole on the front coilovers to allow them to be bolted up. the rear struts are a complete drop in.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Why not use the vw rears you got from the coilovers? I've read that they are direct fit, may need some grinding of the lower mount for rear.
Is there anything stopping someone from just bolting on vw coilovers and calling it a day? Just curious, I realize the spring rates/damping are for a car that weighs 500lb more
Purely curious, I am picking up a 92 Festiva this coming week as a daily driver and have plans of getting a hold of mk2/3 coiloversLast edited by Kenkyona; 11-29-2015, 11:43 PM.Originally posted by bheartsWhat is one man's trash is a festiva owners upgrade. Lol
Originally posted by mikemounlio View PostLets say i want to go a step OR 2 above this setup! What would that look like? I will be getting a large bonus from work this year and the festiva is wanting the top of the line. I have the capri already now i need the festiva to be ready.
Originally posted by Kenkyona View PostWhy not use the vw rears you got from the coilovers? I've read that they are direct fit, may need some grinding of the lower mount for rear.
Originally posted by gergorian View PostYou are right that all you have to do is grind some of the bottom mount off, but the "problem" ( quoted because its not a huge issue) is that the MK3 rear strut bodies are longer. If you go with the MK1 struts they are already shorter than the Festiva struts giving you an instant drop in ride height before you factor in the adjust-ability of a coilover sleeve.
Edit: ahh, just read that the lower mount on the front coilovers from a mk1 have a different bolt spacing then mk2/3, whether that is closer or further to our factory bolt spacing I'm unsure but I see no reason why you couldn't redrill the mount just like the mk2/3 coilovers (has been done, mk1 rabbit with mk2/3 coils), that way you could just buy a full set of coilovers, do some slight mods and be doneLast edited by Kenkyona; 11-30-2015, 12:50 AM.Originally posted by bheartsWhat is one man's trash is a festiva owners upgrade. Lol
what is your guys opinion on these? http://raceland.com/volkswagen-coilo...coilovers.html
I am talking to them to see if i can do front mk2 and rear mk1. Just no reply yet as its very early still.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Originally posted by mikemounlio View Postwhat is your guys opinion on these? http://raceland.com/volkswagen-coilo...coilovers.html
I will call them in a bit and see what they can do for me.
Sent from my SM-N910V using Tapatalk1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
well that is out of the question now. They dont have all the parts to do it at this time. They only do it if they happen to have them.
So what would my options be that would be like the raceland setup i linked from above?
I really like the thought of being able to easily adjust the ride.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
could i still use the rear from an mk2? If so that would make this way easier.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Like said earlier, you can make the mk2/3 rear strut work, but its far from optimal as the strut body is too long for our car.
Your best bet is to piece everything together yourself and forget about the coilover kits. Mk2/3 struts in the front, with 2.5" coilover sleeves and springs. Mk1 struts in the back with 1 7/8 sleeves and springs. You can use 2.5" sleeves and springs in the back but then you sacrifice tire room.91GL BP/F3A with boost
