Originally posted by jason_
Capri calipers on an Aspire knuckle
^ correct about the markings but also about bracket swapping the caliper is 2 peace and the difference is just a few mm to compensate for the thicker rotor it's so close I bet worn out pads on a manual caliper would slip on the autos. You can also put manual rotors on an auto and the caliper will take up the 4 mms
Originally posted by william View Post^ correct about the markings but also about bracket swapping the caliper is 2 peace and the difference is just a few mm to compensate for the thicker rotor it's so close I bet worn out pads on a manual caliper would slip on the autos. You can also put manual rotors on an auto and the caliper will take up the 4 mms90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by bhazard View PostWrong. Manual caliper has 18V stamped in it. Auto has 22V.
Originally posted by F3BZ View Postthe caliper doesn't have 18 or 22V stamped on it. it's the bolt on outboard pad bracket that has this stamping. this is the only difference between an aspire caliper assembly for an AT or MT car. the 22v bracket is simply deeper to allow for the 4mm thicker AT rotor.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
