Jumping around through this Sub Forum I'm trying to figure something out. I'm Fairly certain I know What parts I need to upgrade my brakes to a track worthy setup, but I just need confirmation.
Front Brakes:
Aspire (Automatic trans) full knuckle assembly with ARP press in studs for a Miata, or 2001-2005 Kia Rio Front knuckle assembly. (With either route I must go with at least 13" wheels with a 4X100 lug pattern)
Rear Brakes:
Aspire Rear Beam Axle Assembly with thread in or press in studs, or get a bracket fabricated to install Mazda Protege LX (Kia Sephia?) rear disc brakes ($$$) (Must use wheels with 4X100 lug pattern, but wheel diameter not as important)
Brake Booster:
Ford Aspire (Manual trans), or Modified NA/NB Miata
Brake Master Cylinder:
Ford Aspire, or Escort GT/Mazda Protege LX (for the more budget minded), (Modifications for brake proportioning?)
Any other information you could give me would be much appreciated, I'm just needing to know which parts I need to pull from the local PNP. The have a 1995 Ford Aspire (automatic), 2004 Kia Rio (automatic), 93 Protege LX, 95 Kia Sephia, 91 Miata and a 92 Festiva L. So I can damn near get everything to upgrade the brakes, and a few other things.
Front Brakes:
Rear Brakes:
Brake Booster:
