I know that there has been people who have swapped the full Aspire Rear beam and some that have did a little grinding and fit the Aspire spindles to the Festiva rear beam. But has anybody tried modifying the Festiva rear beam to accept the Kia Rio rear spindle? I would assume it would be easier, once done, to find brake parts, spindles, and drums that don't need to have wheel studs put in.
I don't think it would be too hard to do, but I don't have access to a Kia Rio or the knowledge and experience with drum brakes.
I figure you could take a piece of 2 or 3 mil steel, drill out the holes to match the Kia Rio spindles along with a few holes to plug weld the piece to the beam axle in place of the original Festy or Aspire spindles, as long as the center point of the spindles doesn't move everything should be kosher. You could also make them drop plates to lower the rear a little with the sacrifice of wheel/tire clearance.
Would it be worth it?
