Aspire swap camber issue
  • Aspire swap camber issue
    Hey guys,
    I know there's probably already a thread on this but I can't find it..
    So my steve has the full aspire swap, and the problem is that every time I take a hard turn the camber bolt slips and then the wheel is waaay cambered in.
    I've heard about putting some sort of wedge in there to keep it from moving, any experience with this?
    1991 Beastiva L BP autoX'er
    Top bolt here
      Check to make sure your not running out of thread on the knuckle bolts. I've had that issue and it was the bolt running out of thread before it clamped the knuckle tight. I fixed it with a nice thick washer.
        I use Rio camber bolts on mine and they have thick washers on both ends of the bolt.
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
          aha, I'll take a look an see
            Once again Charlie for the win!
            Big fat washers on both sides now, felt like driving on rails around the neighborhood "test track" compared to the continuously variable camber setup I inadvertently had..
