Rio swap question
  • Rio swap question
    I have the auto transmission in my BP swap festiva. I'm wanting to put my 14 inch rims on it but it needs new bushings and such up front so figured I start looking into swapping it for something better. My question is does the Rio spindles use the stock cv axles for the stock transmission? If not what axles work or is there a better swap to use in my case.
    1990 Red Festiva STOCK "pregnant roller skate"
    1989 Yellow Festiva BP swap "Freebird"
    2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
    2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
    2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
    1994 Ford F150 5.0 Completely stock.
    The late 2002-2005 KIA Rio brakes might not clear some 14" wheels. The earlier Rio brakes will clear. Ford Aspire brakes clear 13" wheels with no problems and work great, but Aspires are getting harder to find at scrap yards. Your stock axles should work on any of these setups, but you'll need the correct outer tie rod ends for them Escort GT tie rod ends seem to be the most commonly used choice.
      My 14" enkei clear my mid 02 rio brakes but its damn close. Actually i have scrap marks on one rim that i guess flexed at some point in time and hit the caliper. If you get the big rio brakes make sure to test fit your rims 1st.
      19?? 150$ burnout car SOLD
      1991 (STRESS RELIEF)SOLD
        I was thinking early 2000s rio. The aspires here are obsolete you never see them. It's going be difficult find a rio but I just figure it be easier than the aspire
          Use car-part.com as a search in your area. That'll probably save a bunch of running around aimlessly trying to locate the parts.
          Hope this helps.
            Hope this helps.
            Thanks. I didn't know about that. The one I usually use got flooded out during the hurricane few weeks back.
              Just to be sure does anyone know the year of escorts gt tie rod ends to use? I have read a couple different things and want make sure I'm ordering the right ones.
                All first gen mazda escort tierods are the same (91-96)
                  OK just checking. Thanks
                    Hope this helps.
                    Wow this website is great. I actually found about 8 close by. Thanks again
                      Just call to make sure they have the parts before you drive over there.
                      Jerry
                      Team Lightning
                      Owner of Team Lightning
                      93 L Lightning. BP
