I have the auto transmission in my BP swap festiva. I'm wanting to put my 14 inch rims on it but it needs new bushings and such up front so figured I start looking into swapping it for something better. My question is does the Rio spindles use the stock cv axles for the stock transmission? If not what axles work or is there a better swap to use in my case.
Rio swap question
Rio swap question
Last edited by 90fastiva; 10-25-2016, 10:56 AM.1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
The late 2002-2005 KIA Rio brakes might not clear some 14" wheels. The earlier Rio brakes will clear. Ford Aspire brakes clear 13" wheels with no problems and work great, but Aspires are getting harder to find at scrap yards. Your stock axles should work on any of these setups, but you'll need the correct outer tie rod ends for them Escort GT tie rod ends seem to be the most commonly used choice.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
My 14" enkei clear my mid 02 rio brakes but its damn close. Actually i have scrap marks on one rim that i guess flexed at some point in time and hit the caliper. If you get the big rio brakes make sure to test fit your rims 1st.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
I was thinking early 2000s rio. The aspires here are obsolete you never see them. It's going be difficult find a rio but I just figure it be easier than the aspire1990 Red Festiva STOCK "pregnant roller skate"
Thanks. I didn't know about that. The one I usually use got flooded out during the hurricane few weeks back.Originally posted by lessersivad View PostUse car-part.com as a search in your area. That'll probably save a bunch of running around aimlessly trying to locate the parts.
Hope this helps.1990 Red Festiva STOCK "pregnant roller skate"
Just to be sure does anyone know the year of escorts gt tie rod ends to use? I have read a couple different things and want make sure I'm ordering the right ones.1990 Red Festiva STOCK "pregnant roller skate"
All first gen mazda escort tierods are the same (91-96)Trees aren't kind to me...
OK just checking. Thanks1990 Red Festiva STOCK "pregnant roller skate"
Wow this website is great. I actually found about 8 close by. Thanks againOriginally posted by lessersivad View PostUse car-part.com as a search in your area. That'll probably save a bunch of running around aimlessly trying to locate the parts.
Just call to make sure they have the parts before you drive over there.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
