Question about a set if rims
  • theastronaut
    replied
    I have them on non-hubcentric spacers so I'm not sure. I'm pretty sure the center bore is larger than the festiva hub.
  • BustaBust
    replied
    do the acura legend wheels have any issues with center bore, I really like them and imagine they aren't hard to find
  • Festiver
    replied
    16x8.5 0offset 205/45r16 23" tall 8" wide they don't fit rubs frame at lock and suspension has to be stiffer to not rub fenders 15x7 +25 with rolledand pulled fenders is maximum width and offset and height
    Sent from my XT1585 using Tapatalk
  • Geminigiant
    replied
    Dang those escort wheels are awesome
  • FestYboy
    replied
    That much stretch is not beneficial or safe in any way.
  • w4rkry
    replied
    Originally posted by reddragon View Post
    For an 8" rim to fit you would need 145/60r13 tires
    You can get much lower profiles than that, no need to do such a stretch
  • reddragon
    replied
  • theastronaut
    replied
    Escort/Tempo wheels in the top pic, they won't fit without suspension mods and adapters. The bottom pic is Acura Legend wheels, they should fit with no mods.
  • Geminigiant
    replied
    I like those rims a lot, what are they off of? And thanks for the detailed posts/pictures. Helping me make my mind up!
  • theastronaut
    replied
    Like Will said, lots of inexpensive OEM wheels to choose from and the Achilles tires are hard to beat for their price, performance, and durability. They're around $200 shipped, can last 30K miles easily, and they do well autocrossing with the right suspension setup.
    I had them on my '88 until I went with 15's so I could use stickier Nankang NS-2R tires.
    If you want to go with 15's then 165/50's are the size you want. Either tire size will be pretty much the same overall diameter as the stock tire size so the speedometer and odometer will read correctly.
  • FestYboy
    replied
    With 8" wide rims, the car will feel like poop well before the chassis gets even close to your limits, let alone the car's limits.
  • w4rkry
    replied
    165/55R14 looks great for a tire-to-wheel ratio. Also, the Nankang ATR-K in that size provides great performance for an even better price.
    14x6 is also very common to find as an OEM alloy from other manufacturers
    - Korean Note 4 via Tapatalk -
  • Geminigiant
    replied
    That is exactly what I needed to know! Ill be on the hunt for 6 inch with then. Why do you suggest 14s over 13s ?
  • w4rkry
    replied
    Originally posted by theastronaut View Post
    I suggest 14x5.5 or 14x6", around 35mm offset with Achilles 165/55-14 tires.
    +1
  • theastronaut
    replied
    Depends on what you mean by "fit". They'll stick out of the fenders, a lot, like two inches. If they rub or not depends on your tire size and if you carry any weight or passengers. It'll still look strange with the tires sticking out so far.
    It'll look about like this with the wheels you posted.
