question on tire rim size
  • #16
    So those should have an offset of 45mm which is why you are rubbing. If I remember correctly the aspire sits a few mm wider than a stock beam so a 10-15mm spacer in the rear should fix your rubbing issues and still allow the wheel to tuck under the fender nicely.
