Finishing touches to the ultimate suspension build
  • Finishing touches to the ultimate suspension build
    Good day,
    I am running the ultimate suspension for almost 2 years now and i can tell you that from the pic that even with the negative 2.5 deg camber no bad wear on the tire..
    Whats i would like to address is that, for the front there's nothing between the strut mount and the top hat, it worked initially but now i have some play between the shaft, what everyone use there, can i get a link to buy that nut, even to grind the edges off..
    Also for the rears i want to run some negative camber at the back, any ideas?
    JAMAICA TO THE WORLD
    I don't complain, i just come plain.
    Originally posted by alpaccino View Post
    Good day,
    [ATTACH=CONFIG]21685[/ATTACH]
    [ATTACH=CONFIG]21686[/ATTACH]
    [ATTACH=CONFIG]21687[/ATTACH]
    The Festiva Store should have Rear Camber plates for sale.
      I just checked, I couldn't find them.
      Dark blue '91 B6t + E series
      Something new breaks every day
