Good day,
I am running the ultimate suspension for almost 2 years now and i can tell you that from the pic that even with the negative 2.5 deg camber no bad wear on the tire..
Whats i would like to address is that, for the front there's nothing between the strut mount and the top hat, it worked initially but now i have some play between the shaft, what everyone use there, can i get a link to buy that nut, even to grind the edges off..
Also for the rears i want to run some negative camber at the back, any ideas?
JAMAICA TO THE WORLD
