I bought the energy suspension ones from autozone ($20) and installed them with the supplied brackets. they worked great but after reading the warnings here i decided not to chance my car to those flimsy pieces of mystery metal. luckily i found the stock brackets behind my house and went at the es bushings with a dremel. have not had a worry since. the only advice i can offer is test fit, test fit, trim. (this means installed on the car not just in the bracket on your work bench).
Poly sway bar bushings?
Super Pro Bushings
Super Pro are a reputable aussie poly bushing company. recently TEIN USA has been appoointed as US distribuutor. Just looked up part numbers for various bushings. Here we go!Originally posted by ericsmith32 View Post:scratch: http://www.fulcrumsuspensions.com.au/fulcrumCat/
Put in Festiva.. they say they're poly but i've never heard of this company before.
SPF1318K - Control Arm Lower - Inner Bushing
Price: $46
SPF1478-22K, SPF1478-24K, SPF1478-26K (22, 24, 26mm bar) Sway Bar Mount To Chassis Bushing
Price: $34
No pic
SPF0161K Sway Bar To Lower Control Arm Kit
Price: $33
notes: Measure bush, 25mm length & flange diameter 47mm, says its for Mazda
SPF1477K Sway Bar To Lower Control Arm Kit
Price: $22
notes: Measure bush, 20mm length & flange diameter 36mm, says its for Ford/MazdaLast edited by Arnie; 04-25-2009, 11:25 AM.
Why did you have to reply to this 2 year old thread when you created a new thread for the group interest?---------------------------------------------------
i replied to this first then saw how old it was but then thought it might be better for the forum in general to start a new thread. I couldn't delete/edit my post by the time I finished up the new thread. Feel free to delete this post or the thread.Last edited by Arnie; 04-25-2009, 08:42 PM.
It's alright with me just some people around here will razz you about it. To bad he's away from his computer!---------------------------------------------------
