This may already have been asked and answered, however i dont got the time to go through and read all of this information. I want install some new springs in my 1990 Ford Festiva LX to lift it up about 3-6 inches. I like to drive over stuff and well last time i did it the frame of the car scraped across the curb. So i want to get either some new springs or an air ride system to lift the car up. Anyone know what kind of springs i would need or how i would do it?
Suspension Lift
one easy solution you can do right away for fairly cheap is get used or new struts and springs for an aspire sense they bolt up with very little to no modification and they are built to support a 200 pound heavier car, thats an idea for a quick fix but your best bet in the long run would be find some multi adjustable coilovers for another car that would fit the festy and just jack it up to its limit.
well a smaller wheel will make it seem higher because you can see more suspension and such but i think it would only have the clearance of a smaller wheel sense it wouldnt be as tall as wide, not sure that it would give your undercarriage any more clearance, I would guess the sky is the limit for raising it though, just need to find a strut that fits and a spring that fits and the festiva will lift a high as they allow it too.
Well you need to realize lifting your festiva up 3-6 inches is going to ruin its driveability, and yes this was answered last week.
Your car's front wheels are going to be so far pigeon foot'ed that you are going to eat through tires every couple of thousand miles. Also your rear end is going to push the rear tires down and forward when you lift it, do to the swing arms pivot point, if your 12" tires don't rub after 3-6" of lift, then your new larger rims will if you go that route.
Also you have to think of the short wheel base of these cars. Lifting them 6 inches, then putting taller tires on them are going to make them even more unsafe around corners.
They actually make off road vehicles than can run stuff over.
