Reverse stagger? Really?
Fitment of 13"x8" wheels... Pictures 56K beware!
FestYboy, what tires are you running that you think would be comparable to Kumho V710's that would warrant such a change? I've Autox'd my Festy w/the stock 12's, 13's w/Falken ZE 512's, and 14's w/Kumho Victoracers. And I have never found I needed smaller tires in the rear. Just wondering. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
The Citroen DS series of cars used smaller rear tires deliberately. However, they were designed that way.
i was running Komo 512s on 14s and couldn't for the life of me get the rear to come around. the rear would stick and the front would start pushing, it sucked. i'm running in STS class so that may make some differance but the principle should remain the same.Trees aren't kind to me...
Needs more adjustable rear Panhard.Originally posted by FestYboyi was running Komo 512s on 14s and couldn't for the life of me get the rear to come around. the rear would stick and the front would start pushing, it sucked. i'm running in STS class so that may make some differance but the principle should remain the same.
Yes Jimmy is right, it sounds like you need to stiffen up the rear, stiffer springs or what I am doing, building a larger anti sway bar. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
i used to have a thread on here about how i stiffened up the rear using auxilary springs for load handling. as it is now, i'll get .5" deflection in the read w/ a 120 lb laod in hte back seat, i can't say you can get that w/ stock springs
Jimmy, are you asking if they fit w/the Aspire brakes? If so, yes they do. In fact I have the larger Auto Aspire brakes all around. And FestyBoy, I did notice the post w/the helper springs. I want to do something like that but I think that is just a band-aid rather than really fixing the problem. I'm looking into the Tein's or the possibility of having some stiffer rates made for me. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
They are differnt. someone on a budget I would recommend xr2 spindle/big brakes for the front and keeps the same pattern.Originally posted by JimmyNo. Someone had posted above me asking if the Civic wheels had the same bolt pattern as the stock Festiva...
Must've been deleted..."Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
RIP DJ
I just noticed this. You're mounting 215 wide tires on 8" wheels. I think they're going to be a bit stretched to fit. Ideal for a 195 is 6", you're only adding an inch to the tread width. You might want to look into the hoosier A6. They make a 225/45, which will be about the same rolling diameter and might fit the wheels better. The trade off is that they are about $30 more per tire.
I just realised sumitomo makes a 215/50/13. Might make a good street tire.OX SMASH!!
Yes I understand it isn't necessarily "ideal" but is and will work just fine. Miata guys run the 215/50's on 8" wheels and EVEN 9" wheels. In fact, the way the Miata community talks, it only helps having them a bit stretched. -Kyle
PS 710's > A6's...Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
Exactly. I asked a Tirerack guy about it and he said don't do it. But everyone else that actually AutoX's their car says that's the best way to have it. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
