Is the lower one attached to the bottom of the struts?
Ian
I would weld brackets to the frame instead of attaching the bar to the shocks on top. You want those to be able to wiggle a little, you don't want the frame twisting.
Also, I hope that lower bar isn't attached to the struts. That would act as a massive rear sway bar, making the rear end way too loose. The rear is pretty strong laterally, if you're looking for more anti-sway try boxing off a couple inches on the torsion beam.
Yes the bottom is attached to the struts on the bottom..and i made my other one off of the rally festiva off of the picture gallery....it does wiggle a little bit. You not suppose to over tighten the top strut nuts causing the bushing to sqeeze out over that metal collar.
How does it handle at the limit? Does the backend feel too tight? Does it cause the car to be unsettled over slight bumps in a corner? Please elaborate. I am going to box off the Aspire beam w/1/8" plate but would like some other options/opinions as well. -Kyle
Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Besides my plan is to cut the floor and weld the top bar to the bottom bar....
i hate to burst your bubble, but if you weld the top to the bottom, you'll either 1) break the welds, or 2) bust something on your chassis when you go over any hard bump or dip.
what i'm saying is, if you weld top to bottom, you'll loose any and all rear suspension travel; like having a solid axel welded straight to the frame, and that's not a good thing.
