Originally posted by iceracerdude
What is the aspire brake swap advantage?
They are, that's why you don't want to use them.
I keep an Aspire CA around just to have it to compare with.
On ebay, some of the CAs are sold with more hardware. Look around and compare prices.
Easy to tell apart. The Festiva can be used on either side so if you look at it from above it will be straight. The Aspire is right or left handed and there is a bend to it.
they are which is why you keep the festiva ones for the swap. the hubs are the same basically, if you use aspire control arms it will put your bottom part of the hub out farther than the top, messing up your camber like crazy1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
Poverty produces creativity
