What is the difference between the auto an manual aspire front setup? Can I use the either, does it matter at all if my Festy is an auto or manual? I looked up the festy and it seems the axles are the same so I assume the hubs are the same. I just need to know before I strip the assfire.
Front aspire issue
Originally posted by niklid05the autos rotors are thicker than the manual rotors. You can use either auto or manual, just make sure you get both from the same car."Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
RIP DJ
I honestly havent done the swap but that is one thing I noticed when I got my stuff (look at the thread below this one.). I would think that the autos would be better braking, I wasnt sure thats why I asked that in my thread. someone will hopefully answer our question...91GL, 93L, 91L, 92L
00 f250- xlt 7.3 6speed 4x4
88 gtx
74 torino- enduro car.
Originally posted by Sho_tyme_psiOriginally posted by niklid05the autos rotors are thicker than the manual rotors. You can use either auto or manual, just make sure you get both from the same car.
The calipers and rotors need to match. If you have auto calipers then you need the thicker auto rotors.
The calipers are 2 pieces and the bracket that holds on the pads is what is different between the auto and manual setups. You can use manual or auto calipers just use the correct bolt on bracket. There are 2 bolts that hold the caliper together, I think they are 17mm hex.
Originally posted by mattswabbThe calipers and rotors need to match. If you have auto calipers then you need the thicker auto rotors.
I believe you are right about the caliper bolts being 17mm. The caliper to spindle bolts are 14mm.91GL, 93L, 91L, 92L
88 gtx
Here's a pic of what I was trying to explain. See how the caliper comes apart. The part with the piston in it is the same for botht the auto and manual cars. The bracket on the left is what is different. The bracket for the auto cars needs to be longer to accomdate the thicker rotor.
Some parts stores ask you if its for a manual or auto car some don't. That's because some are only selling you the part on the right.
Thanks Matt! Interesting.
FWIW, I've bought at least 2.5 sets of calipers with core trade, and I've always gotten the whole shebang. Not until Matt put up that pic and explanation did I know Aspire calipers were "two piece."
One or two piece? Calipers aren't as easy as women's swimsuits... :lol:
