so you tapped the threads with F body studs? why did this cause the torque steer the wheels where loose? more info please
Cant keep it on the road PROBLEM FIXED!!!!!!!!
to get the studs in the hub did you have to drill the holes out? where did you find the studs? are they the perfect length? how did putting studs in instead of using the lug bolts help the car from being so squirley? does that help? im asking cause maybe ill change my set up i hate using those stupid lug bolts and then you have to worry about cross threading the hub what pain in the butt
