brake swap, capri/aspire?
  • brake swap, capri/aspire?
    What is the difference between either of these swaps? Is there any reason to do one over the other? Do they use the same wheels?
    Sofar from searches I've found that the capri brakes are larger but don't bolt up as easily, is this right?
    Also, how much heavier are the aspire/capri parts than stock festy?
    OX SMASH!!
    I have no experience with the capri brakes. From what I've seen the capri rotors bolt on like the festivas which is terrible way to attach them. So I would lean towards the aspire. There are a few posts on the capri brakes.
    Don't worry about the weight. I'm sure the aspire brakes are heavier than the festivas but the stopping difference is well worth it.
    They aspire and capri will fit the same wheels.
    matt
      Well, with how little the rear brakes do I am wanting to keep them as light as possible.
      I just thought of another question, some aspires have ABS right? what would it take to get that working on a festy?
      OX SMASH!!
        REAR BRAKES
        use aspire unit (with the beam) improve braking and suspension.
          The advantages of the Aspire brake and suspension swap outweigh any weight penalties, unless you are modding your Festiva for airworthiness.
          When I do my next suspension swap, I hope to document the weight differences between all the different parts. I'm just curious.
          My guess is that the rear Aspire beam swap creates a greater weight disparity than does the (manual rotor) front swap.
          Improved braking, increased rear roll stiffness, and having a nicely functioning parking brake are very much worth the work! (Plus the greater ease in doing your front brakes.)
            airworthiness huh, that sounds like a good idea. There are some nice railroad tracks near here that are perfect for jumping.
            I was thinking I want to make my car able to do stoppies. My friend who was tailing me said it looked like I was close.
            I think when I do the swap I'll take it for a drive before I do the back.
            If I manage, I'll get pics.
            OX SMASH!!
              hmmm if you can pull off a stoppie make sure your friend is taping it, the first might just be the last lol
                well, from what he said the rear susp was at full travel, with a stiffer front I am hoping for like 1-6" of lift on the rear wheels. It would take a lot to get the nose to touch down since as the engine drops the CG moves back and down. All it would take is me lifting the brakes and the car would drop back, might be a hard landing, but with no weight back there it should take it. I hope...
                OX SMASH!!
