I had found the perfect set of 13" wheels when the seller on Ebay became stupid. I have found a set of 14" wheels and I need to know if I can make them work. They are 14x5.5 and are 4-100mm. With the aspire swap I know this is not a problem. Now for the fun part, the offset. The offset for these wheels is 45mm. Please tell me there is a way to make this work!!!!!!!
Question regarding 14" Wheels
your 14" wheels will have about a 4.5" Backspacing. Stock BS is about 4", since your wheel is
1" wider than stock using these wheels will add about 1/2" to both sides of the wheel. In theory
these should work on a festiva. The main issue will be finding the right tire that doesn't rub.
On the other hand I think 5.5" is to skinny for a 14" wheel. I would look for 6" or wider.Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
