Well from just sitting in the garage doing nothing my master cylinder decided to start leaking. Aswell, my brake booster is a rusty lump. While im at it im going to replace both. I think i have read that the aspire master cylinder bolts up and is better than the stock one. Is this correct? What about the brake booster? Will it bolt up too?
Aspier brake booster & master cylinder?
You will have to move the line at the front of the master.stock screws in from the side.Aspire screws in from the top.
Booster should bolt up with no problem if same diameter.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
I want to complete my brake swap and do the booster/MC as well. Please do tell use has the braking improved?? pedal feel??---------------------------------------------------
i did the aspire swap and still have the stock booster/MC and the brakes work awesome
With the Aspire stuff the pedal feel is much better, less pedal effort creates more stopping power. Worthwhile mod... -Kyle
EDIT: I have the Aspire AUTO booster and MC in my car (It is bigger still)Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
A tubing bender is what I used to do both of my front lines. I figured since I was in there, I might as well replace the line with brand new. I went to Advance auto parts and picked up a straight section of brake line, got a tubing bender and custom bent my lines. It worked like a charm.90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
