I tried some rims I found in a junk yard. They were on the 4 hole list. They are 84 nissan sentra steel rims. When the guy at the tire shop put them on he said they weren't "hub centric" and he couldn't get them on straight. I test drove it and I'm getting a shimmy in the front. He rebalanced and it didn't fix it. Any thoughts
I tried nissan sentra rims. They gave me a shimy shake. Help
they are called hubcentric rings. you need to know the bore of the rim and the diameter of your hub on your festiva in order to get the right ones.
you can pick them up on ebay or probably any autoparts store...
I had steel hubcentric rings made for my 13 X 5.5" VW alloys to fit the Aspire brake/hub conversion. Cost me over $115!
if you have a caliper, you should be able to measure the bore on the festiva hub and the rim.
