Going to install this tomorrow, It will alos have a fuel pressure gauge installed
uses an-6 lines and fittinings
1- fuel cell of you choice, most have 3 AN-8 fittings , supply, return , vent. ( reqiuires AN-8 to AN-6 adapters, see below)
1- Fuel pump, walbro external pump, 130-225 LPH
( see other thread of fuel pump http://www.shoforum.com/showthread.php?t=92466)
2- AN-6 to 10mm x 1. adapter ( for fuel pump)
4 - 90 deg fittings
4 - straight fittings
2 - AN-8 to AN-6 adapter to attach 90 deg to fuel cell
1 - AN-6 inline filter of you chioce
1 - AN-6 roll over valve for fuel cell ( not shown)
1 - AN-6 to FORD quick disconnect, supply
1 - AN-6 to FORD quick disconnect, return
Enough AN-6 line to finish the job
4 - 90 deg fittings
