minigun , it moves
Awesome Mike! Drank some of that Dogfish beer while I was painting a room today! Thanks! The Indian Pale Ale is not bad. Don't you hate when you've lost your nuts?
Here is the thread where he starts it up.http://www.fordfestiva.com/forums/sh...ad.php?t=23630Originally posted by FestivaFan View PostWhen you do take it out for a ride, get some video of this thing. I don't want to see it so much as I want to HEAR it!
BTW, sorry about the underwear. :p
minigun , it moves
Got just about everything hooked up , enough for a test drive anyway. Fired it up and let in warm up a couple miunutes.
Moved the shifter around , felt fine , clutch was working smooth. Shifted it into R and gave it a little blip of the throttle and eased out the clutch. It moved
Did the same thing in 1st, not much gas just enough to prevent stalling. Okay this was working fine.
So I move it back and forth a few times, a little more gas each time. I was getting cocky and gave her a good rev and let out the clutch....
BANG !
Note to self. install motor mount bolts !
No damage except to my underwear. The motor mounts have studs that go out the bottom and though the frame with a nut on the back side, I guess they are laying around here somewere. The motor just jump up a little to remind me of my stupidy.
If the next couple days I should be able to post a video of it under its own power.Tags: None
