Ordered the eBay fuel rail adaptor mentioned earlier. It won't get here until Oct. 5th tho; then I can install my AFPR. Meanwhile, Tuesday my wideband should get here, so I'll get it on probably Wednesday afternoon, and can drive around with it and report what it says.
Went to my two fave JYs yesterday. One had a gen2 323 I was gonna take a bunch of parts from, but it's already gone, dangit. I was thinking of getting the intake and modding it so I could just do a quick swap and have minimal downtime. I'll have to wait for another one to come along, or maybe I'll just go ahead and do up this one. I have a spare Aspire intake to practice on; if that goes well, it'll go on in place of the current Aspire one, when I stick the Matthew B3 long block into the Aspire. (Which I better get to fairly quickly, now that it's starting to get cooler.) The Aspire already has a Dickmeyer header, but stock Aspire exhaust after that (without a cat tho).
Took some pics of the dyno readout; this one seemed the most usable. Note that the readings only go to 4000 RPM for the first run, and ~3450 for the second run. Also see how flat the AFR is, on the bottom of the chart. Seems odd, and not sure what it means exactly. But it does pull quite hard all the way up.
For comparisons, look at the Matt D. B3 dyno sheet (post #153), from the same shop.
