Tom's B6 Build Thread
  • #61
    Greg, you're using a B6 header, right? (at least that's what it looks like from the pic). if so, do you have a particular reason why you didn't use the B3 header? (i'm wishing i did).
    • #62
      That's what was on the motor when it came out of the parts car. I don't think it's even for a mazda. If you look it has some extra holes drilled to make it fit. Is it possible to use the b3 manifold/header? ( i haven't compared) It would make install easier, and promote torque.
      -Greg
      Redneck Engineer
      FOTY - '09
      • #63
        if its the over the valve cover(early B6) variety yeah the b3 header would work
        • #64
          Ok thanks. it's a newer b6 where the throttle body points to the drivers side.
          -Greg
          Redneck Engineer
          FOTY - '09
          • #65
            That's probably the reason for the extra holes drilled in the header flange. I think the header was made for the early b3/b6 exhaust bolt pattern.
            I don't think the bigger tubes of the B6 header will hurt much, since forced induction doesn't rely as heavily on the exhaust primary tubes to aid in cylinder filling. If anything, the larger tubes may help increase flow to the turbo. They may decrease the initial gas velocity and/or reduce the boost pressure, but with the rear mount turbo so far away, the remainder of the exhaust system will be the determining factor. I would certainly wrap the tubes to keep the heat and velocity up. This is just my .02 opinion. I don't know a lot about turbocharging, and even less about rear mounted turbos............. It would be interesting to first run it with a stock B6 manifold and then switch to the header, just to see what the difference is! Keep up the excellent posting - can't wait to see the results!
            I'm sure TominMO is going crazy with anticipation!
            • #66
              I think your correct about the flange holes. And I do hope it won't matter as much. And as far as rear turbos I'm still learning and always will be
              I do plan on running it with just the b6. Then with the turbo.
              -Greg
              Redneck Engineer
              FOTY - '09
              • #67
                Wow, great job Greg. What did you use to paint the valve cover? Did you blast it first?
                Man, it really looks great.
                No longer a festiva owner
                • #68
                  ...I do plan on running it with just the b6.
                  Prediction: 16.60 @ 81 mph.
                  • #69
                    I would love to do a rear turbo setup on mine, but I don't think an open element air cleaner under the car would work out for me on a daily driver (not in Nebraska). I thought about putting the air cleaner housing inside the car and run a duct to the outside of the rear quarter panel. Maybe then put a small side scoop just in front of the passenger side tail light for ram air.
                    I have a lot of questions, so I'm glad your posting this thread!
                    • #70
                      Yeah Tom sand blasted it while he was here. And the paint is "duplicolor engine enamel" and the color is "cast aluminum coat" Thanks
                      Good. I think that's fair. And I think turbo should be 15.5ish.
                      Yea if he didn't have the spare tire well I'd put it there. I think it can be hidden in a few spots. We'll have to see where it ends up.
                      -Greg
                      Redneck Engineer
                      FOTY - '09
                      • #71
                        Ok Update time again........................
                        After work I went to the hardware store and auto parts store to get more parts.
                        Got Tom some "new" axles. No remans here. Grabbed some axles seals too. Might as well replace them while I'm there.
                        Also the intake gasket came in, so I was able to put the intake back on. Thanks to Tom, it was already clean.
                        I also painted the fuel rail (it was rusty), and made the harness how it needed to be. Moved the tps plug and retaped the harness.
                        I also got the timing belt cover trimmed and installed. Motor mount bracket, and alternator bracket cleaned, and installed.
                        So here is a before and after pic of this motor. I think it looks a litttle bit better. Hopefully I'll be putting it in this week/end. I'll keep the updates coming.............................Note:new shiny hardware
                        -Greg
                        Redneck Engineer
                        FOTY - '09
                        • #72
                          The engine looks good, you can definitly tell the difference.:thumbright:
                          '90 LX
                          • #73
                            Greg, that engine looks really nice!:happy5:
                            Dan
                            • #74
                              Thanks Guys. I got the tranny, and starter cleaned up too, but not really worth a picture
                              -Greg
                              Redneck Engineer
                              FOTY - '09
                              • #75
                                How big are those tubes?
