Psychobilly Festiva- '93 GL Sport BP/F5MR, one piece at a time
Mini update: Ran winter autocross with the B3 last weekend. Kinda sucked not having a good heater in the car (or nearly enough winter gear, as i found out while marshalling for the 4WD guys) but it was a blast. More fun than racing on pavement if I might say.
Looking at probably February to drop the BP in at this point.
mmmmmm 2 step drool
when the engine is running DONT check andthing around your spark plugs or wires... with just my VERY OLD accell coil i shocked the heck out of my self lol... i would hate to see how bad it would be with a msd set up
Mike, AKA the sasquatch
Indeed. I've zapped myself 3 or 4 times on stock ignitions (all of them were from cracked plug wires or boots), don't wanna find out what it feels like to get a shock from this box.
Worst one I've seen was a guy diagnosing a no-start on a '50s Chev I6. Couldn't feel or move his arm for like half an hour.
I seen arcs coming from the Coils on my rx7. I reached down to move the wires away from the other one and nearly pee'd on myself. That was the last time I did that.
Looking foward to seeing more progress.
Really old tyme juice...
LOL I never actually did this; but, my father and uncle and friends used to reminisce about hiding a Model T coil under grass or straw, then get someone to urinate on the thing while hooked to a battery. 40,000 volts crawl directly up the stream of pee to knock off a person's whang or whatever!Originally posted by anomoly40 View PostI seen arcs coming from the Coils on my rx7. I reached down to move the wires away from the other one and nearly pee'd on myself. That was the last time I did that.
Looking foward to seeing more progress.'91 Festiva L/'73 Windsor Carrera Sport custom
K my head is spinning here. Ignition stuff has always been confusing to me, more so when MSD's diagrams and documentation are vague at best when it comes to anything that's not an american V8 or a honda.
I want to set this 6AL up on the B3. I have no idea if it even works, so I'd like to set it up now to check that, and it would make for less work when I'm doing the swap so as to minimize the time spent in a borrowed garage, and I don't want to have to do any major work after the swap.
How in the crap do I wire this thing?
Also, it's my understanding that I need a tach adapter so that the ECU knows what's going on. Is that true, or is someone blowing smoke into one of the more personal areas of my body? and if so, which one (8910 or 8920)?Last edited by Tommychu; 02-03-2011, 04:16 PM.
Its very easy to install POWER that's the big red wire go to batter +, big black wire that's the ground anything steel will work. Next is trigger orange goes to the + side of the coil pack, Black goes to - side of coil.
White connect to your - factory coil plug wire coming from your ECU.
small Red connect to the + factory coil plug wire coming from your ECU.
YOU NEED A TEST LIGHT AT MIN or GET A MULTIMETER FOR SAFE TESTING!
TACH adapter = 8910 easy white to white T connection red goes to Small red T connection.
Thanks
Welp.
I busted my head today. The BP, not my skull. Not going to post why, suffice to say I'm an idiot. Might post that in an arena thread, but I can't say what happened without a little coarse language.
I'll likely be putting a B8ME head on it so I can just get this swap over with. Anything I should know? Will my 9.5:1 pistons be an issue? I need a different water pump and timing belt, anything else?
why not just get another bp head? check the protege, escort and miata forums...
