Glad you got the supension figured out
Hope all goes well on the seal repair tomorrow as well Karl!
I have to get my temp gauge working, put in the right side seatbelt, and finish the interior. And keep checking things...
(Yes, corrected for the larger 175/70-13s at a 7 percent difference.)
I also tested it by unhooking the thermoswitch plug at the thermostat housing so the fan would run by default. Since I had no helper to turn the switch, I unhooked the negative battery cable and turned the ignition to "on." Then when I wanted to test the fan, I connected the negative cable and I was right there to see everything, vs, inside the car where I would have seen little or nothing!
