A few years back I put a carb off of a dodge omni or something like that on a old 1988 Mazda pick-up and on one of the forums I learned that the Holley 5220 was very much like a Weber. I was able to find one for cheap in that junk yards. I think I payed $25.00 for it.
Could be a cheaper option?
Attempting the Weber carb install
Well I think part of my issue is I decided to use my stock air filter housing. Which I believe is starving the carb of air so I just purchased the air filter from weber. It should be here within 5 days. So we will see when it arrives.
Yeah I got the more expensive one 32/36 Dfev. Thats probably where I went wrong. Spending to much time fabricating the throttle to work.Originally posted by zoe60 View PostI put mine on yesterday and it runs great. The DGEV is definitely the one to use because the throttle turns the right way and ends up real close to the original location. I used the Festy carbs throttle linkage and moved the throttle cable over about 5/8". Still in the original bracket. I also kept my MAP sensor hooked up and was careful witch vacuum devices I got rid of so my CEL doesn't come on. Mine is a Redline kit for a Suzuki Samarai (1.3 litre) and the idle mixture screw is tuned best at 2 turns out witch is what they recommend. Runs very smooth and has great throttle response. Hope to get some pictures on here soon.
That would be correct, to set the idle screw you turn it in till it seats lightly then back it out two full turns. if you have to go less than 1.5 turns in your idle screw is too large, more then 3 out or so its too small.Originally posted by zoe60 View PostI put mine on yesterday and it runs great. The DGEV is definitely the one to use because the throttle turns the right way and ends up real close to the original location. I used the Festy carbs throttle linkage and moved the throttle cable over about 5/8". Still in the original bracket. I also kept my MAP sensor hooked up and was careful witch vacuum devices I got rid of so my CEL doesn't come on. Mine is a Redline kit for a Suzuki Samarai (1.3 litre) and the idle mixture screw is tuned best at 2 turns out witch is what they recommend. Runs very smooth and has great throttle response. Hope to get some pictures on here soon.
My ICT's came with .052 jets in them and i ended up having to bump them up to .060's because i had to crank them way out to get a proper idle!
Well I think it needs to be tuned, but i am not sure. It seems that when ever I put my air cleaner on it bogs down and it likes to bog down when i am taking off in any gear. Just a few minor things that I need to work out.Originally posted by IdealSociety View Postwebers are thankfully pretty easy to tune. i had a 32/36 progressive on my VW (a hackjob carb for a type 3, since they arent like a bug motor over the top carbs stick out of the engine bay) and it was super easy to tune.
Now i have a pair of Weber ICT 34's. Most of the tuning on a weber comes from the idle circuit. If you google redline weber tuning they have a really nice guide for tuning.
I wish the stock Solex carbs im replacing the webers with were half as easy to tune!
Well got her to fire up, but she stills needs some fine tuning. I am hoping that in the next couple of days that she will be running smooth. When it is I will post what I did to help others to make this a smooth process as much as possible.
I would love to pics, but I would rather wait until she is running right. The good news is she started tonight. The bad is she wont stay running or she will idle really high. On top of that the choke wont close all the way, which is the reason why I bought this carb in the first place. I am thinking about trashing this project, but I think I will sleep on it and calm down. I am just a little frustrated after the two to three days of fabricating, just to have this new carb do the samething as the original one. I guess we will see what happens next.
zoe60 good luck. I thought mine would work out just fine too, but turns out I need to do more fabricating. I almost lost it today while working on it. Partially cause I was losing patience and wanted it work today. Oh well, maybe tomorrow.
I got a DGEV and the throttle linkage off my spare Asian bolted right on. I think it's going to work perfectly. I'll find out this weekend.
I'm using a Weber 32/36 dfev. Right now it bolts up, but I am currently working on the throttle issue. I am doing everything at the lowest cost possible (except for the carb). So I have managed to make (with some help) an adapter. I also was able to keep my current air filter housing. All we did is cut it to fit over the carb. This gives me several benefits. I dont need to spend money a new air filter, I dont have to worry about the placement of the hoses that connect to the side of it either. Now if I can only get the throttle figured out.
you guys just need to stock up on spare parts like me so you always have extra carbs motors, trans ect
then again ive been in the festiva modifying game for a while
with that said im interested in this since ive never actually bothered with carbs (im 24 so im the FI generation of auto enthusiasts) however since i now daily a 68 VW Squareback with dual webers carbs have kinda caught my attention.
What weber are you using? i think if i went carbs i would try to adapt a set of side-drafts like the vw rabbit guys tend to use. an extra intake mani and some home-made flanges could probably squeeze them in there quite nicely and give the stock motor (or any swaps really) a nice throaty sound and a bit of uniqueness!Last edited by IdealSociety; 11-10-2010, 08:21 AM.
This should be the finished product.
The picture beneanth should be my fix for the throttle. I will let you all know if it works out. We just simply cut and trimmed the throotle linkage off of my original carb and drilled a hole so that we could fasten it to the new carb.Last edited by brickdog2000; 11-06-2010, 08:56 PM.
