Attempting the Weber carb install
  • FestYboy
    replied
    ok, well you can still add in the timing till warmer weather hits. also, since your using your factory carb, have you replaced the o2 sensor? if not, get a Denso unit. also have you learned to read spark plugs? another step you can try is hit the ABC valve with some PB Blast overnight (it may be sticking).
  • smurfstiva
    replied
    oh i dont know about jets i still have the stock carb and did a rebuild on it a while back got the timeing right and everything and then it just went to crap again. i hate that thing. but efi is so involved
  • FestYboy
    replied
    yeah you!
  • smurfstiva
    replied
    who me?
  • FestYboy
    replied
    weather will do this to you. take advantage of the cooler air and add 3-4* of base timing for ignition. what jets are you using and what's your idle air bleed screw set at?
  • smurfstiva
    replied
    ok im trying to keep up but my carb is killing me i get 33 all the time and its driving me crazy. forinfo i got 40 before i bought a new engine and upgraded to a 5 speed and full sythetic oil??????????? thinking about ripping my 93 apart and getting the goods for efi but gawd thats alot of work.
  • drddan
    replied
    Originally posted by brickdog2000 View Post
    I will be posting pictures sometime this weekend of what the finish product looks like. I have to give thanks to drddan. He put up with me hounding him with questions through out this project.
    No problemo! Glad I could help.
    Hey, you can always add to my REP power!
    Lets see those pics!
  • brickdog2000
    replied
    Okay the pictures are being delayed due to the fact that the festy isnt running right. After research I discovered that the disty advance is not hooked up correctly. It was never hooked up correctly to begin with. So this weekend I will hopefully get this thing runnin right.
  • brickdog2000
    replied
    I finally got the festiva running. It took awhile waiting on jets and finding time. She runs a little rough, but I am happy just to have her running again. I did end up plugging the distributor advance, which is opposite of what everyone else did. I just couldent get the car drive right with the distributor advance hooked up. It would idle fine, but as soon as I would take off in 1st gear I couldent go over 10mph. I will be posting pictures sometime this weekend of what the finish product looks like. I have to give thanks to drddan. He put up with me hounding him with questions through out this project.
  • zoe60
    replied
    Yeah you are probably right. The thing is, I'm getting ready to put a 1.6 in it so I guess I'll leave it alone for now. May be OK with a b6.
  • TominMO
    replied
    Originally posted by zoe60 View Post
    I just checked my mileage and it went down. 33 MPG's Before I did anything it got 38. With the performance cam it got 36. With the cam and the Weber it got 33. I don't know how much of that can be attributed to winter gas and me flooring it a lot with my new goodies. Just thought I'd pass on my results. It's still way more fun to drive and I'm glad I did it.
    Guess what I believe? But try leaner main jets if you have 140s; I think 140 is probably a little rich for such a small cylinder (325cc). I have used the same Weber on three different cars, all of which were 1800cc 4-cylinders (450cc per cylinder), and they used 140 main jets too.
  • zoe60
    replied
  • drddan
    replied
    Well cool, glad I was an inspiration! :p
    Good luck on the 323 and keep us posted....
  • zoe60
    replied
    Well, I basically copied the whole idea after you. I just threw my own spin on it. It was a fun upgrade. Made me think a lot but was not all that difficult. I still can't believe the difference in power and how much smoother it runs. Now I'm getting ready to bolt all that stuff onto a 1989 Mazda 323 b6 I've been working on. Hoping for the best. Thanks again for the Idea- Kenny
  • drddan
    replied
    This is the bottom part of the adapter plate that I made. At this point I still needed to counter-sink the holes on the corner.
    Here's all the parts before I put them together.
    Ok, here's the whole thing assembled and ready for the carb.
    Aha! Here's the entire assembly!
    And heres the whole thing installed on the car! I think it looks like it was made for it. Whadaya think? Oh, I forgot to mention, I do have a bench grinder too.
    Zoe, you are a Hacksaw Master! Good work. That is a very good idea using the Samuri kit. I had wondered if that would work when I was looking into adaptors. I wasnt sure, so I just built the whole thing myself.
    Worked out that I needed more height anyway as I used a Weber DFEV, instead of a DGEV, and I wanted the choke towards the front. I needed extra height for the choke to clear the valve cover.
    Your pic of your motor reminded me of mine, especially with the little valve cover breather filter on there.
    Here is my adaptor
