ok im trying to keep up but my carb is killing me i get 33 all the time and its driving me crazy. forinfo i got 40 before i bought a new engine and upgraded to a 5 speed and full sythetic oil??????????? thinking about ripping my 93 apart and getting the goods for efi but gawd thats alot of work.
Attempting the Weber carb install
weather will do this to you. take advantage of the cooler air and add 3-4* of base timing for ignition. what jets are you using and what's your idle air bleed screw set at?Trees aren't kind to me...
yeah you!Trees aren't kind to me...
oh i dont know about jets i still have the stock carb and did a rebuild on it a while back got the timeing right and everything and then it just went to crap again. i hate that thing. but efi is so involvedIt's Not Much To Look At, But It's Still Funny To See The Look On Their Faces When They Catch Back Up To You At The Next Light!
ok, well you can still add in the timing till warmer weather hits. also, since your using your factory carb, have you replaced the o2 sensor? if not, get a Denso unit. also have you learned to read spark plugs? another step you can try is hit the ABC valve with some PB Blast overnight (it may be sticking).Trees aren't kind to me...
use an inline pump if you want to switch, that way you don't have to touch the tank. like THISLast edited by FestYboy; 02-11-2011, 10:25 PM.Trees aren't kind to me...
nope.... both can see the better part of 40mpg on any given day, but the carbs are more suceptible to climate change and since there are more parts involved, there's more that can go wrong with them.
also note that i added a link to my previous post.Trees aren't kind to me...
winter is about 34, summer is 38-42 and that's with a B6Trees aren't kind to me...
