M3NTALS B6T Build Thread pics always
Thanks!Originally posted by M3NTAL View PostThanks for the kind replys guys, Im trying my best here
Well I'm running..
Aspire swaybar
Xr2 half shaft
Xr2 Axles
G series trans
Aspire Lower Contol Arms
10.2" Capri Xr2 rotors
Capri Calipers
Kyb GR2 Struts (for A Festiva)
Aspire Springs
Festiva tie rod ends
Festiva rack
That's about itLast edited by Advancedynamix; 07-23-2011, 12:08 AM.
Rough estimate
Going to get a EFI washer tank so that I'll have room on the passenger side for the IC piping, might as well cause I have a EFI harness! Lol
Only downfall to capri brakes is the smallest wheel you can run is a 14 inch. All the common drag slicks are 13 inch. I'd trade my capri brakes for aspire brakes but I would miss some stopping power
Originally posted by Advancedynamix View PostIf you don't mind me asking (and I have tried searching several times but haven't found a solid answer) what axle/ control arm/ tie rod combo did you use with the g25MR and the XR2 brakes. I want to order all new stuff to do mine, but I don't want to end up with more spares that don't fit, Lol. Shed is full already!
Great build by the way! Love that color, and doing it with A/C! Nice:thumbup:
Well I'm running..
Aspire swaybar
Xr2 half shaft
Xr2 Axles
G series trans
Capri Calipers
Aspire Springs
Festiva rack
That's about itLast edited by M3NTAL; 07-22-2011, 12:41 AM.
Running IC piping, and a radiator hose here is going to be fun!!!
Man I hope I have cold ac, all this turbo heat is going to be killing my ac, I think im going to run another fan infront of the condenser to help with air flow.
Yeah it's not going to work straight down towards the front, the hood will def hit.Last edited by M3NTAL; 07-21-2011, 10:04 PM.
Have you tried closing the hood with your iac piping in place ?? Looks like it might be little high , but pictures tell stories .. IT looks good nice progress .
July 21 2011
Well I was having problems with clearing the tranny mount with my lower radiator outlet (92-95 Civic Aluminum Rad) so I cut the lower part off, welded that hole shut, and relocated the outlet to the side and welded her up!
Fitment:
Interior wiring is done !!!
